3gen gs spyder convert to dohc
i have the 4cylinder 2.4 liter engine
i need to know what kind of head i need to do this ive been hearing about evo9 head and the dodge neon. what Do i need as far as a head |
evo 8. the evo 9 is a mivec i believe, so im not real sure if itll work. theres also some hyundai head that can be used. but other then that youll need the cams and head gasket, i believe you need longer head bolts or something along that line, i never really kept up with it a whole lot. the timing belt to go with the head also
is there any other vedicle dohc cylinder head i can use besides evo heads because there like 2000 dollars used
no there is not. Why go dohc? unless you are turbo or sds it will not help you enough to warrent the $ spent
i have the turbo kit i jUST WANT TO HAVE IT DOHC B4 I PUT IT ON
no need to yell about it.......
i wasnt yelling the caps got stuck man. but do u kno of any heads that would work
Evo8 head is going to be worth the $$$ if your turbo and building up the bottom. you will have a car capible of lots and lots of power. Not that you will be able to get traction
