a/c is out...
RE: a/c is out...
water shut off motor?? i have work for a mitsubishi dealer for 20 yrs. never heard of that on an eclipse. what exactly are you trying to do?? was the 65LBS on the low or the high side?? at idle with a/c on, low side pressure should be 28- 35 LBS high side shold be 150- 200. on a really hot day the high side pressure could go as high as 250LBS. if you have 65LBS on the low side, compressor is bad. also replace the dryer. that acts as a filter to the a/c system. compressor could have come apart and sent debris into the system. dryer should catch most of it. so replace it!! good luck!! greg...
