Check Engine Light
#23
RE: Check Engine Light
You should take readings on the 2 sensors and see which one is in normal specs. Think about it the ECU is checking both sensors then comparing them. One is coming back way too far off so the comp is throwing the code for both cuz it doesn't really know which one is right.
#26
it could be a number of things. i would started by getting the O2 sensors CHECKED. do not get them replaced unless you want to pay $150 a piece. get them checked to make sure that they are the problem. if they are not the problem, then get the cats checked. they can also cause similar problems.(however, usually it also gives a code for the cat). if none of those are the problem, then you may want to check the MAS.
have you done any modifications to the car? is it still stock?
#27
the only thing that is throwing me away from the 02 sensor being the problem is that when mine went, it told me exactly which bank was the problem, but definetely at least do what eclisped4u said.
