-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   drain hose (https://mitsubishiforum.com/forum/3rd-generation-64/drain-hose-29050/)
jptexas Sep 2, 2008 04:40 PM
drain hose
Hi everybody,
I need your help.
I would like to unclog a clogged drain hose, as it appears. (no drip under the car when AC is on, driver side gets wet).
I understand the best way is to remove debris in different places.
A mechanic removed some debris behind the glove compartment.
This still looks like it s clogged. I would like to try to unclog some more from the bottom of the car, but I can't locate that hose.
I would really appreciate if anybody could tell me where to find that hose from underneath, so I can try to run a wire through it.
Thanks!!
