Eclipse 4g64 oil light
Old Jan 23, 2010 | 02:52 PM
wakawu's Avatar
Default Eclipse 4g64 oil light
Just purchased a 2002 Eclipse 4g64, 5-spd manual. The oil light comes on at idle but quickly shuts off when throttle is hit just a bit. Is there an easy way to verify the oil pressure or should I just replace the oil sending unit? Also, where is the sending unit on these engines?
Old Jan 23, 2010 | 03:21 PM
dsm1990gsx's Avatar
Is the oil level full?
Old Jan 23, 2010 | 06:56 PM
wakawu's Avatar
Of course, that was the first thing I checked I even overfilled by 1/2 a quart just to make sure with the same result. Oil light at idle, instantly goes away when I touch the throttle
Old Jan 27, 2010 | 10:27 PM
wakawu's Avatar
Ookie doke, changed the oil, filter and pressure switch. Turns out the valve cover was leaking all over the back of the engine and some oil got on the switch so that will be replaced next and all is good.
turbo1600
Apr 25, 2021 01:58 PM
filipinohustler
11
Nov 22, 2011 01:49 AM
TheRock0720
Nov 12, 2010 12:30 PM
tidus10
Apr 7, 2006 05:39 PM
Laxstar785
Jun 14, 2005 08:51 PM
