-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   Engine shakes a little? (https://mitsubishiforum.com/forum/3rd-generation-64/engine-shakes-little-23588/)
bk3939 Nov 19, 2007 10:05 PM
Hello,
Whenever I come to a complete stop with my heater on I notice my engine starts to shake a little. It is noticable thru the steering wheel. I have a 2004 gts automatic. If i turn the heater off of full blast it doesn't shake no more. any help would be great.
N/Teclipse Nov 19, 2007 10:08 PM
RE: Engine shakes a little?
You probably aready thought of this but the only time I have heard of shaking in the steering wheel when stopping is A. your rotors are warped or B. Bad eng mount. I have never heard of the problem being caused by the heater, that shouldn't make a difference.
bk3939 Nov 19, 2007 10:23 PM
Yea I"m not sure. But when i turn the ac on or the heater the engine starts to shake and i notice it. Its still under warranty and I'm not sure if I should take it in. I dont want them to do nothing.
N/Teclipse Nov 19, 2007 10:27 PM
Now is the eng shaking or is the steering wheel shaking, and when you turn on the ACC what does the RPMs do?
estraw Nov 19, 2007 11:32 PM
well he said he's at a complete stop when it happens, so you can rule out the rotors. put your car in 1st, or park (depending on weather your car is manual or auto) with the car off and open the hood. rock the car back and forth as much as you can and see if you can see the engine moving more then about an inch. also listen for any noises coming from your motor mounts when you do so.
bk3939 Nov 26, 2007 11:48 AM
Thanks I will try this and let you know.
Maddler Dec 10, 2007 02:09 PM
I also have a shaking engine, but mine is only when stopped. If it's in Drive then it shakes worse than if in Park. It was shaking enough to be a minor annoyance in the summer, but when the weather got colder it now shakes enough that it sounds like the something is rattling against the hood. If it's a bad mount, does that mean that it's just loose, or will I have to have the engine removed to replace the mounting hardware?
