Engine Swap
I was wonderin, has anyone tried to do an engine swap to put a turbo charged awd 3000gt motor into an 03 gts? Any info would be appreciated.
RE: Engine Swap
hahahhahahhaha.lmmfao
RE: Engine Swap
Cant happen. Dont even talk about it.
RE: Engine Swap
actually there is a tube chassis drag eclipse that used the 6g72tt at one point...and it is possible...just not feasable
RE: Engine Swap
doesnt the eclipse gts already have a 6g72 engine? therefore youd just have two twin turbo itif anything is wrong dont yell at me im mechanically challenged :)
RE: Engine Swap
yes it does but it is also sohc and much different from the dohc 6g72 found in the tt 3/s's... im not sure if a dohc swap has been done on a 3g v6?
RE: Engine Swap
could you just swap the head off of the dohc 6g72. More than likely im wrong but never hurts to ask.
RE: Engine Swap
You can make a V12 3G using a tube chassis, Dave. lol. Theres a lot more to that than just a head swap. THe motors dont even mount up the same way. If you really want to do an engine swap with that car, why dont you look more into the 6g74 swap. Its a lot more plausable.
RE: Engine Swap
thanks
