Headlights?
My headlights seem pretty dim. What can i do to make them brighter. Some of those blue zenon might look good. Suggestions? I just want to be able to see better at night.
RE: Headlights?
it could be that your headlights are going out....just buy some aftermarket bulbs, you should be fine.
RE: Headlights?
The alternators suck in these cars... thats normal.
RE: Headlights?
Check your wirings...the ground wire in particular or check ur wiring harness its known to get real hot n melt like a grilled cheese
RE: Headlights?
You might be able to help that with a grounding kit
RE: Headlights?
ORIGINAL: Sebba The alternators suck in these cars... thats normal. |
RE: Headlights?
Alternators too? That's funny that you mention that because I just had trouble starting my car and the battery wasn't dead
RE: Headlights?
ORIGINAL: Camel3g GT Check your wirings...the ground wire in particular or check ur wiring harness its known to get real hot n melt like a grilled cheese and if your considering new bulbs, the eclipse isnt good for HID kits....they use a lot of amps that most eclipse models lack. |
RE: Headlights?
well i definately just orderd new halos and 12k hid kits for my 2001 gs... not a good idea then???[:@] wish i read this sooner.
