where is located radio amplifier in 2003 GTS?
Old 08-18-2005, 12:14 AM
jacek's Avatar
Default where is located radio amplifier in 2003 GTS?
Hi, I am looking for radio amplifier for mitsubishi eclipse 2003 GTS. Originally this car has Infinity radio system and it looks like power amp is separated from the main unit. such as the display. Could anyone help me with diagram or hint where I can find it?
Thanks,
Jack
Old 08-18-2005, 10:07 AM
Default RE: where is located radio amplifier in 2003 GTS?
Check under the passanger and driver seat.
Old 08-18-2005, 03:43 PM
Patrick's Avatar
Administrator
it IS under the passenger seat...mine went bad...
Old 08-18-2005, 10:34 PM
jacek's Avatar
thanks, I will check and will lt you know how to fix ( if ) I will fix it. Mine went bad when eclipses window was open during a long rain. some water accumulated on the carpet and I think it caused the damage. This should be mounted somewhere higher.
Jack
2003 eclipse GTS
Old 08-18-2005, 11:05 PM
Patrick's Avatar
Administrator
they short out very easily, mine did so from hitting a bump [:@]
Old 08-19-2005, 10:29 AM
Do you have any type of sub woofer(s) in the car?
Old 08-19-2005, 10:30 AM
Old 08-19-2005, 12:05 PM
Patrick's Avatar
Administrator
who, me?
Old 01-29-2017, 08:00 AM
Sean Thomas's Avatar
Default Do I need too remove the seat?
Hey guys,
I just picked up an 03 Spyder GTS, and my amp is also pooched. Do I need too take out the front seat too access the stock amp?
Old 01-29-2017, 08:15 PM
firebuck's Avatar
It would be easier for sure. Just label any connectors you need to unhook such as seat-belt and airbag so it is easier to hook them back up.
roybliz
09-14-2010 07:36 PM
galant4eva
08-27-2005 09:49 PM
e46fanatik
07-19-2005 02:52 PM
ton
02-23-2005 05:05 PM
aznbballa4lyf
01-01-2005 03:44 PM
Quick Reply: where is located radio amplifier in 2003 GTS?
