-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   low beams really dim (https://mitsubishiforum.com/forum/3rd-generation-64/low-beams-really-dim-22164/)
ricks01 Sep 14, 2007 09:15 AM
Hey guys I'm new here and I have a problem with my 01 Eclipse. My low beams are super dim even with new bulbs. Hi beams seem normal. Have you guys ever seen this problem? I would appreciate any ideas.
Sebba Sep 14, 2007 03:15 PM
RE: low beams really dim
Get a ground kit. Basically its a thing that connects to the negative battery terminal and connects to multiple ground kits.
953kgtvr4 Sep 16, 2007 10:34 AM
Mine used to do the same thing i replaced the harness for like two dollars and they are fine now. The old harnesses are usually melted for some reason.
ricks01 Sep 17, 2007 08:02 AM
thanx guys.
hdtech Sep 22, 2007 01:26 PM
I have a similar problem. Are you talking about the wiring harness to the light itself? Or is this the neg terminal on the battery running into the main electrical unit on the engine.
I assume the light itself but it seems to be a pain to get off? Is there a diagram somewhere? Where do you get the harness??
Thanks in advance
hdtech Sep 22, 2007 01:51 PM
Perhaps I am slightly retrarded! I got them off with a little more effort and thought.
One harness is melted with one terminal on the light itsefl is corroded. Are the hardnesses only available from the dealer? I assume you just splice into the old wires.
Thanks for helping this retarded newbie!
Sebba Sep 22, 2007 02:25 PM
The only other place you could find the harness is on another car.
hdtech Sep 22, 2007 11:30 PM
Thanks Sebba. What about the ground kit you referred to. Is this somethings different?
Another thought would be to get some newer lights. Would that solve the issue?
Sebba Sep 22, 2007 11:43 PM
Yeah thats something different.
I dont htink new lights will actually make a difference. Not all of the current is making it to the ligts and you need to find out why. Change the harness and see what that does.
hdtech Sep 23, 2007 11:36 AM
Good news. One of the termnials on the light itself didnt look to great. It had some corrosion. So I got out my polishing bit on my Dremmel and cleaned each terminal. That worked to perfection!
Both lights are little brighter now and things look great. Now the glaring spot is the external housing/casing on the light. It has weathered over time. Outside of replacing those, is there somemthing to make them look a little better??
