Problems with Radio disply and cig lighter.... Help??
Hey, I have a 2003 Eclipse and I'm having a few problems with it. For about six months now my digital display on the dash (that shows the radio station, etc.) doesn't even come on. Also my cigarette lighter doesn't work. I checked the fuses in the car and they all seem to be ok. If you have any idea what could be a potential problem, please let me know. Thank you
RE: Problems with Radio disply and cig lighter.... Help??
I could, and probably am, but is there another set of fuses?
On my 2G Eclipse, there were 2 sets of Fuses. There was one under the hood and one under the dash on the drivers side under the steering wheel. could check there.
I had the very same problem with my 2000 GT. In the fuse box inside the car is a fuse marked cig lighter if I am not mistaken it is the 3rd down 2nd row from right. The box says to use a 15 I have used 15 and 20 both work fine however, when ever you use that lighter the fuse blows again. Major defect yet not a recall. Just don't use the lighter you should be fine. BTW the lighter outlet in the armrest is not on that current so use that one for charger. Or keep a few fuses in car at all times.
