Removing Door Trim
I have to replace the Drivers Mirror on my daughters 2004 Eclipse. Any tricks on removing the inside door trim? Every car has its different locking mechanisim - I just dont want to PRY and snap them off?
RE: Removing Door Trim
There should be screws around the bottom maybe? I'll check my own door today, i'll get back to you.
Already done _ Thanks all. 2 Screws on the Door panel (Front and Rear). 1 Screw in the Door Handle. Simply pried out the Trim starting Top/Left. It Simply Snapped out.
2 Connectors (Pwr Windows) and Mirror. 3 More Screws easily accesable around the Tweeter and Mirror and it all Popped out. Putting the Panel on took a few minutes but it was a lot easier when I removed the Window Seal from the door first. Snapped the panel back in and then snapped the window seal back on. Piece of cake. |
| All times are GMT -5. The time now is 06:47 AM. |
