Squeeking?
Old Nov 16, 2006 | 02:23 AM
newEclipse's Avatar
Default Squeeking?
Alright, I am sure someone else has had this problem. I have already changed all brake pads, and checked the rotors, and they don't have to be turned, but I am still getting a squeeking problem. The wierd thing is that it only squeeks when I am accelerating slowly, and it only squeeks in the back.
Any Idea's At this point I am open to anything
Thanks
Old Nov 16, 2006 | 02:30 AM
silvercoupe97's Avatar
Default RE: Squeeking?
It could be your e-brake pads, they may be just tight enough to squeak. Did you put any anti-brake squeak on the shims, if so, did you put enough?
Old Nov 16, 2006 | 08:08 PM
Sanguinius's Avatar
How long have you driven on the new pads? Some brakes do have a break in period of a few hundred miles where they MAY or may not squeak.
Old Nov 17, 2006 | 10:31 AM
newEclipse's Avatar
Yes I have used Anti Squeek, and Yes I most definitly used enough. I think I have driven the car for over a hundred miles since i changed the pads, but it doesnt squeek when I brake. Only when I accelerate slowly.
Old Nov 17, 2006 | 10:35 AM
N/Teclipse's Avatar
Mine do that too, its only when I first start up though because my e-brake is needing to be change bad.
Old Nov 17, 2006 | 08:38 PM
ORIGINAL: N/Teclipse
That's what I would check next. The e-brake pads could be worn or they could just need adjusting or you didn't put the e-brake handle down far enough or the handle cable needs to be adjusted.
There, IMO, that's a good start
Old Nov 22, 2006 | 11:34 PM
newEclipse's Avatar
Do the third gens have e brake pads, or does the e brake use the same pads as the rear calipers do?
Old Nov 23, 2006 | 12:06 AM
Sanguinius's Avatar
Ooo that's a good one... I don't even remember now it's been so long since I've worked on a 3rd gen... I think they have the seperate brake pads on the inside of the rotors.
Old Nov 30, 2006 | 11:59 AM
newEclipse's Avatar
oh that makes sence, ok thanks let me look.
Old Nov 30, 2006 | 12:04 PM
newEclipse's Avatar
Ok so if I were to adjust the ebrake cable how would I go about doing that?
