-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   sunroof issues (https://mitsubishiforum.com/forum/3rd-generation-64/sunroof-issues-35157/)
66ca Feb 23, 2010 09:29 PM
sunroof issues
trying to get an idea of where to start looking on the sunroof problem. Just got my son a 2000 Gt and the sunroof doesnt open. I checked the tiny fuse on the side of the dash and its good. When you push the button, it makes a slight and faint click at the switch, but nothing else. It will do it each time you press the button. Is there another fuse somewhere, or should i start troubleshooting it somewhere else? Any ideas?
Killswitch Feb 25, 2010 08:55 PM
sunroof problems are pretty common, on mine i push the button and the roof my move ever so slightly, then i can push it up to loosen it and then i pull the button back again and it will work, so in my case it just gets stuck alittle too much and the motor cant pull it back without some help. i know some people have replaced the sunroof motor which has fixed it but i do not know the price or anything on it. you could also clean out the tracks and lubricate them to see if that may help any
Dusty Eclipse Mar 3, 2010 10:21 PM
SOunds like the motor... but I believe if the radio fuse is bad it can cause this too... or the cigg lighter fuse...
66ca Mar 4, 2010 02:32 AM
well the radio still works just fine so i guess its not that fuse....but the cig lighter has been taken out for some reason, so i will look at that fuse today. Thanks for the suggestion
es5hf6w Mar 7, 2010 11:12 AM
If you have read your service manual and tried the button withing the trunk compartment then i do not have any advice but if you have not this could be the problem it its switched to manual.
66ca Mar 8, 2010 02:36 AM
i dont have a service manual so i cant do what you are referring to. So there is a way to switch the sunroof to manual? And there is something in the hatch area that does this? I have no clue as to what or where you are talking about, so if you could please tell me i will look and see if this fixes my problem. Thanks
farrukh Nov 15, 2021 03:05 AM
Defaultsunroof problems are pretty common, on mine i push the button and the roof my move ever so slightly, then i can push it up to loosen it and then i pull the button back again and it will work, so in my case it just gets stuck a little too much and the motor cant pull it back without some help. make grinding voice. even my sunroof not tilt because arm was broken and sun roof stuck at the end i am from Pakistan Karachi why not Mitsubishi solve it and export from Tokyo to Karachi. there are many people who are facing this problem of Mitsubishi lancer 2005- 2008 sunroof problem even the local dealer dewan motor haven't, any solution.event they said parts has already stopped. any one help on it i need to fix it.
smithbrown Oct 5, 2025 01:25 PM
Originally Posted by farrukh (Post 334301)
Defaultsunroof problems are pretty common, on mine i push the button and the roof my move ever so slightly, then i can push it up to loosen it and then i pull the button back again and it will work, so in my case it just gets stuck a little too much and the motor cant pull it back without some help. make grinding voice. even my sunroof not tilt because arm was broken and sun roof stuck at the end i am from Pakistan Karachi why not Mitsubishi solve it and export from Tokyo to Karachi? Many people are facing this problem of Mitsubishi Lancer 2005–2008 sunroof issues, and even the local dealer Dewan Motor doesn’t have a solution. You might want to look into sunroof services that specialize in repairing or fabricating replacement parts. Anyone help on it? I need to fix it.
It’s likely the anti-pinch feature being triggered. Clean and lubricate the tracks with silicone spray, check the seals for debris or swelling, and try resetting the sunroof by holding the close button for about 10 to 20 seconds until it cycles open and closed. If it still stops and retracts, the motor or sensor may need adjustment or replacement by a professional.
