2001 Eclipse GS Spyder P0170 code
Old 03-18-2018, 08:10 PM
oscarrod73's Avatar
Default 2001 Eclipse GS Spyder P0170 code
My car has 150,256 miles. I need diagnostic help to find out why vehicle is idling rough, I am receiving code P0170. It stalls at start. After starting and idle at 2000 rpms, short term fuel trim is at 24 while long term fuel trim is at 6, according to scan tool. When I step on accelerator it feels like it should be running great but as soon as I let go accelerator go, idle goes back to around 678rpm and STFT/LTFT remain the same. I have replaced EGR valve, IAT valve, MAF sensor, O2 sensor, coolant temp sensor, and TPS. Nothing seems to help.
Old 05-13-2018, 03:16 PM
Widgmaster's Avatar
Possible causes
Intake air leaks
Faulty front heated oxygen sensor
Ignition misfiring
Faulty fuel injectors
Exhaust gas leaks
Incorrect fuel pressure
Lack of fuel
Faulty Mass Air Flow (MAF) sensor
Incorrect Positive Crankcase Ventilation (PCV) hose connection
xgains
06-26-2013 04:18 PM
menacemonty
11-12-2012 10:45 AM
dsm1990gsx
01-24-2009 11:16 PM
Natedogg89
04-13-2008 08:54 PM
drakon
10-23-2007 07:08 PM
Quick Reply: 2001 Eclipse GS Spyder P0170 code
