Traction...
Question..... Is there anyway to turn traction control off on the GTS model ...3G?
RE: Traction...
do they even have TCS?? those cars have the worse tration of all time.... BTW if you arewanting to spin your tires you will crack you daskboard up by the windsheild, all 3G Eclipses do that both of mine did and on top of that the motor mounts really suck and will wear out quickly
RE: Traction...
just replace the motor mounts with firm ones from deyeme and you will eliminate most of the wheel hop.
PS....STOP DROPPING THE CLUTCH AND YOU WON'T SPIN |
RE: Traction...
ORIGINAL: eclipsed4u just replace the motor mounts with firm ones from deyeme and you will eliminate most of the wheel hop. PS....STOP DROPPING THE CLUTCH AND YOU WON'T SPIN |
RE: Traction...
Actually I was just having some fun in our first snow strom here in Jersey :). And yes the GTS model does have TC, but not a switch for it, at least not that I know of.
RE: Traction...
i don't believe you can turn it off. but you must have one of those special GTS'....b/c i think you are the first with traction control.
RE: Traction...
ORIGINAL: eclipsed4u i don't believe you can turn it off. but you must have one of those special GTS'....b/c i think you are the first with traction control. But like I said I really dont think they had TCS do you have some sort of TCS light that comes on when spinning or on startup? again I have never once heard of it on any 3G |
I know this thread is old but yes they do have traction control and yes i would like to know a way to disable without hurting anything
