turbo v6?
Old 12-07-2006 | 12:09 AM
da boss's Avatar
Default turbo v6?
Hey everybody I am just wondering what it is going to take for me to get a turbo up and running in a 2003 v6 and what times it should run? I have about $5500 i am willing to drop into the car for the turbo and I know the kit is $3500 but what else am I going to need besides tuning to get it working properly? I will already have done headers, CAI, catback, and a tune (or is it not worth it with out some serious mods like a turbo) Thanks for any posts that are worth something.
Old 12-07-2006 | 12:23 AM
93eclipsegsx's Avatar
Default RE: turbo v6?
wont be able to use the headers,cai and go to tearstone.com for the turbo kit.
Old 12-07-2006 | 08:57 AM
tearstone kit on stock motor will run 8PSI as long as your a GT if your a GTS it will be less cause the motor has weaker pistons.
8 PSI will get you 320HP and run mid\low 13s if you need more then you NEED pistons first.
CAI Hearders and tune WILL all be changed with a turbo. so you can re sell the headers and the CAI and maybe what ever you are using to tune with as well. the tearstone stuff all together will run you about $5500 all said and done needing nothing further to run 8PSI.
dont forget these turbo kits dont come with gauges of any kind or a clutch and you will need both
Old 12-07-2006 | 10:12 AM
RCJr9186's Avatar
i'm not sure what all comes with the tearstone kit but does it come with any kind of engine management? if not, you will need one.
Old 12-07-2006 | 06:19 PM
ORIGINAL: RCJr9186
it comes with the greddy Emanage. you need to buy gauges and a clutch... if it were me id also look at LSD motor mounts and some good tires too
aznspyder
25
11-28-2007 04:57 PM
turbotalon95
06-29-2004 02:38 PM
scrappy24
04-07-2004 11:04 PM
GSkiDD
01-29-2004 08:04 AM
Eclipse_GSX
07-10-2003 02:34 PM
Quick Reply: turbo v6?
