Weird Vibration and shaking
Old Nov 1, 2007 | 08:14 PM
Silver00GT's Avatar
Default Weird Vibration and shaking
Ok so this weeks problem is my car sort of vibrates in a pulsating manner when making longright turns like on a highway where the road bends right for awhile. You can feel it in the steering wheel it kinda feels like somethings loose but not sure trying to describe it best i can. Other than that it makes the same vibration on straightaways and left turns but only intermittently, not all the time, only sometimes, but the right turn all the time when going fast like 60-80mph on the highway. Just replaced the left and right engine mounts and they didnt help too much but they were clearly shot so i dont regret it.....any ideas??? thanx
Old Nov 1, 2007 | 09:00 PM
estraw's Avatar
Default RE: Weird Vibration and shaking
you need either rotors, allignment, or your lugnuts arent torqued down
Old Nov 2, 2007 | 02:39 PM
bk33's Avatar
just to add to what estraw said tires may need balanced also.
Old Nov 2, 2007 | 02:51 PM
Silver00GT's Avatar
I just had all the tires balanced, alignment done, and the lugs are torqued properly.......rotors look fine and i dont know why that would even be considered its more of a rattle in the steering column, i know what rotors feel like when there shot its definitley not the rotors, so that clears everything mentioned so far......anyone else?
Old Nov 3, 2007 | 01:12 PM
bk33's Avatar
brand new rotors can warp its do to heat.warped rotors would make it shake. thats all i can think of.
Old Nov 3, 2007 | 01:54 PM
More specifically its due to uneven heating and cooling.
Old Nov 3, 2007 | 03:52 PM
dsm1990gsx's Avatar
Check to see if the suspension is tight andcheck to see if your tires are balanced. Usually warped brake rotors will only be noticed when your braking.
Old Nov 3, 2007 | 09:00 PM
estraw's Avatar
not necesarily true, you can sometimes feel them if you get goin fast enough, and like he said in his first post, when hes going 60+ mph
Old Nov 4, 2007 | 01:03 AM
Dusty Eclipse's Avatar
How about the hub?
Old Nov 6, 2007 | 10:06 AM
blagovest's Avatar
I thing that is tha axel.
