-   3rd Generation (https://mitsubishiforum.com/forum/3rd-generation-64/)
-   -   What clutch to recommend (https://mitsubishiforum.com/forum/3rd-generation-64/what-clutch-recommend-28948/)
Genosyne Aug 26, 2008 12:28 PM
Okay just found out the clutch in my 05 GT is going out and am looking for a new one. I have been told to go with a 6 pad, puck, button clutch as a replacement to my OEM one. I have researched ACT, Exedy, Clutchmasters, and Spec. I have seen mixed reviews from all of them. I am wanting to know what I should go with, will it screw up my transmission, do I need to replace the flywheel, and what will it do to my overall engine life?
I would prefer a clutch that isn't organic, that can stand up to hard driving (street), that will last more than 3 years (if possible). The OEM clutch has lasted approx. 36,000 miles. I am told by another member in the forum that my clutch should have lasted longer.
Any ideas or knowledge would help.....Thanx
TheEngineer Aug 26, 2008 03:08 PM
RE: What clutch to recommend
if your clutch only lasted that long then it seems someone didnt know how to drive a standard that owned it. But i wouldnt go with a 6-puck since youll loose alot of the streetability from it. Just go with a street disc. Just make sure you get a sprung disc. And i would stay away from spec. But the other three are all decent clutches
Genosyne Aug 26, 2008 03:26 PM
What do mean by streetability? I was remiss with the term and applicational use of "rev matching", and I burnt the clutch. Though I am now practicing the technique.
Thanx
