06 Eclipse GT tip
I just changed my oil to synthetic Mobile 1 and now I increased 50hp.
Just kidding on the HP. In case you ever plan on swapping shift kobs or getting a different shifter boot here's a few tips. Aftermarket shift knobs don't work due to the reverse lever built into the shifter. You can modify but probably not worth it. The shifter boot, center console, and metal boot plate are all one peice. When you remove the center console cover over the shifter you'll find out that the peices are actually plastic welded togethor. The shifter boot is samwitched in between the plastic. Hopefully I can save some of you some time by knowing that up front. |
RE: 06 Eclipse GT tip
welded plastic[:-]? cheap ass imports...
