Blower motor location
Will someone be so kind to tell me the location of the blower motor (not the resistor) on a 2007 Eclipse?
thank you in advance. |
No one? Anyone? Please.....
I was hoping I could access it from under the hood as opposed to through glove box/dash. |
Some info...
I doubt that you can access it from the engine compartment. It looks like they hung the heater in the air and built the rest of the car around it. It's under the dash.
MODE SELECTION DAMPER CONTROL MOTOR REMOVAL STEP >>A<< 1. MODE SELECTION DAMPER CONTROL MOTOR POWER TRANSISTOR REMOVAL STEP • GLOVE BOX ASSEMBLY, INSTRUMENT PANEL PARCEL BOX (REFER TO GROUP 52A, INSTRUMENT PANEL P.52A-21). 2. RESISTOR BLOWER MOTOR REMOVAL STEP • INSTRUMENT PANEL UNDER COVER (REFER TO GROUP 52A, INSTRUMENT PANEL P.52A-21). 3. BLOWER MOTOR OUTSIDE/INSIDE AIR SELECTION DAMPER MOTOR REMOVAL STEP • GLOVE BOX ASSEMBLY, INSTRUMENT PANEL PARCEL BOX (REFER TO GROUP 52A, INSTRUMENT PANEL P.52A-21). 4. OUTSIDE/INSIDE AIR SELECTION DAMPER MOTOR https://ww2-secure.justanswer.com/up...-03_152036.png (ignore the yellow box around the resistor) |
