Fog lights only when I use "brights"
I just purchased an 07 Eclipse Spyder and I can only seem to get the fog lights to turn on when the light switch is in the "brights" mode. Is there any way I can be in normal mode and still have fog lights on?
RE: Fog lights only when I use "brights"
Foglights have a relay that turn them off when high beams are switched on.
Make sure the fog light switch (wherever its located at in a 4g) is turned on and the lights switch on to the low beam setting. |
