-   4th Generation (https://mitsubishiforum.com/forum/4th-generation-65/)
-   -   Seat Belt Chime (https://mitsubishiforum.com/forum/4th-generation-65/seat-belt-chime-17976/)
I Drive Naked Jul 3, 2007 12:47 AM
RE: Seat Belt Chime
ORIGINAL: bsj8377
ORIGINAL: indyjr
Good news. Mitsu makes a seat belt extender that you can leave clipped in that will turn off the chime and still allow you to buckle up up safely when ready. Best $34.95 I have ever spent!
You spent $35 on a seat belt extender...when all you had to do was cut or remove one wire...WOW...
I wonder if I can sell the how-to for $20 a pop...
Yea, but you cut that wire and something with the SRS messes up... GOODBYE WARRANTY!
stuntjunkie Dec 10, 2007 01:00 PM
RE: Seat Belt Chime FIX
I have a 2008 GT Spyder. Here is the fix, Make sure the seat belt is not fasten.Unscrew the two torx screws on the seat belt holder (receiving) and carefully removed the cover. On the cover there is a small slide switch that moves each time the seat belt is "Clicked" in. You simply push that little slider all the way down then reinstall the cover carefully not to squish the two wires. The Seat Belt thinks its always fastened. When you want to put it back just reverse it no problem! It's so freak'n simple a caveman can do it!!! Please buckle up though!I disabled it because I want a little more time to do buckle my seat belt and not have to deal with that annoying chime! For god sakes your in a convertable an overturn without your seat belt can = Death! Yes you can be as stupid as a caveman too!
bsj8377 Dec 18, 2007 02:07 AM
RE: Seat Belt Chime
ORIGINAL: Joshewuhh
ORIGINAL: bsj8377
ORIGINAL: indyjr
#1. Why would anything mess with the SRS? It's exactly the same as plugging the seat belt in...
#2. WTF are you talking about with "Goodbye warranty"...??? You don't really think Mitsu can void your entire warranty for disabling the seat belt chime, do you?
Kfborn Dec 19, 2015 06:09 PM
Disabling seat belt chime
Easy solution. Take seat belt from back seat and buckle to driver . That way you don't have to cut wires
Kfborn Dec 19, 2015 06:10 PM
Buckle back seat belt to v front if you don't want to cut wires
Guyfromhe Dec 19, 2015 07:59 PM
I just put my seat belt on and it goes away.
I think there may be an option in ETACS about the seat belt warning though, not 100% sure.
Brandacoon Jul 31, 2021 08:54 PM
Originally Posted by indyjr (Post 124864)
Does anyone have the codes and sequence for disabling the seat belt chime. Not interested in "faux" buckles. Save the buckle up comments, I just want to travel the parking lot and my lengthy driveway to mailbox in peace. Other mfg have been willing to share but Mitsu dealer and tech sx are no help. Thanks!
take the cover off and slide the little plastic partdown the seatbelt chime will always be off
the2reesez Mar 10, 2025 11:15 PM
Here’s the best and easiest way to turn off the chime permanently! My 10 year old figured it out all by himself… buckle up!!! BUT WAIT!!!!
… this time buckle up before you go to enter ur Mitsubishi and sit down; and then just leave it. FOREVER AND EVER! Simple as that.
