4th Generation This includes all Eclipses built in 2006 and 2007.
Shift knob
Old Oct 15, 2006 | 10:34 PM
leedesert's Avatar
Default Shift ****
Are there any shift ***** that will work with my 06 Eclipse? The problem is that lift ring for reverse that sildes into the bottom of the factory shift **** when you pull it up.
Old Oct 15, 2006 | 10:37 PM
Default RE: Shift ****
If you would want to change it i think you would need to remove that mechanism all together. Why would you want to change it anyway?
Old Oct 15, 2006 | 10:39 PM
leedesert's Avatar
Just wanted something a little more modern than the leather ball.
Old Oct 15, 2006 | 10:43 PM
I wouldnt try it....
Old Apr 24, 2007 | 01:09 AM
Crimsin's Avatar
I had the 03 Tib, it had the same thing. I took it off and put a different **** on it. IT wont hurt anything if you take it off
Old Apr 24, 2007 | 01:11 AM
Dude its from 06!
Old Apr 24, 2007 | 01:47 AM
Crimsin's Avatar
Well if it was from 06, why did you say somethin? I will just put your *** on ignore
Old Apr 24, 2007 | 01:48 AM
Thats nice. I said something because i felt the need to so you know not to do it again.
Old Apr 24, 2007 | 01:51 AM
50ul }{4ck3r's Avatar
[sm=WTFsgign.gif]
Old Apr 24, 2007 | 01:56 AM
No **** man... last time i checked i was the one with 5.5k posts??
