-   Audio/Visual Electronics (https://mitsubishiforum.com/forum/audio-visual-electronics-21/)
-   -   02 eclipse sterio, door lock, clock problem (https://mitsubishiforum.com/forum/audio-visual-electronics-21/02-eclipse-sterio-door-lock-clock-problem-24888/)
stephengrossman Jan 22, 2008 06:41 PM
Well I was jumping my car the other day and It got jumped fine. but after I jumped it i started up my aftermarket cd player and it went for like 1 second and turned off. the clock does not work either since whatever happened happened, and same with the clock. So the clock, cd player, and auto door locks dont work... does anyone know the problem? I checked ALL the fuses and they are all good. and when the keys are in the ignition and the door is open it doesnt make anoise anymore.. anything will help. thanks.
Dusty Eclipse Jan 22, 2008 07:34 PM
RE: 02 eclipse sterio, door lock, clock problem
The fuse may look good and still be blown... have u tried changing it?
stephengrossman Jan 22, 2008 08:19 PM
no i havnt because they all looked fine. I take it, the fuse that i would try and replace would be the chime one correcT?
