09 LANCER SUB PRICE
MY 09 LANCE GTSHAVE NO SUB INCLUDE, IF I TAKE IT BACK TO ADD THE SUB ON, HOW MUCH IS GONNA BE?
AND MY AUDIO SYSTEM LOOK LIKE DONT HAVE EQ FUNCTION.IS THAT BECAUSE I DONT HAVE THE SUB? |
RE: 09 LANCER SUB PRICE
as far as i know you need the rockford sun & sound package (at least that's what it's been called in the previous generation, not sure what it is now). You're probably looking at an entirly new vehicle if you take it back, because you're going froma a 4 speaker system to a vehicle with a factory amp & sub. my suggestion is go aftermarket, it'll sound so much better than any factory system and you'll end up spending less.
It's still called the "Sun and Sound" package which includes a sunroof, amp, addl. speakers...
You'll be better off with a full aftermarket set-up if you're otherwise happy with the sound in your ride. The "Sun and Sound" package really does sound great though. It's not enough to piss-off neighbors or impress people at the stop light but it sounds great and hits hard. If you're thinking of buying a new Lancer, the Sun/Sound kit is well worth it - especially with the Navi system. |
Also, as far as I know there is no dash kit available for the latest generation of Lancer, but any installer worth his salt could probably come up with something. It's a double DIN head unit, if it keeps with many newer imports it'll be an ISO mount set up, so you might even be able to use factory brackets to incorporate a new head unit. If you want to keep your OEM radio, use an adjustable line output converter wired into your rear speakers to get signal for a sub amp.
There's install kits... I just saw a couple of them on eBay.
ORIGINAL: BellaCroix There's install kits... I just saw a couple of them on eBay. |
ORIGINAL: Lil Evo Single or DD? And who are they by? As long as it's a reputable company, I'll keep that in mind should I get a new Lancer inmy shop lol. DD & SD: eBay Item number: 140268645133 $54.95 DD & SD: ebay Item number: 360091789215 $32.95 DD & SD: eBay Item number: 130257700309 $32.95 (All above by Metra) DD: eBay Item number: 120307933980 $36.99 DD: eBay Item number: 310085276398 $36.99 (Manufacturer not listed but looks nicer than the Metra) ... Google search also shows several others, I've also talked to a friend who works at a local install store and they don't have them in stock but he can order them. The '09 shares the same basic dashboard as the '08 so they've had more than a year to make an install kit. Look around, you'll find one. Now if you want the custom sub housing from the Sun and Sound package that's probably going to take a trip to a boneyard (or pay dealership prices). |
