Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Hooking up...stock 10 cd changer to aftermarket Radio
Old Jan 7, 2007 | 11:15 PM
50ul }{4ck3r's Avatar
Default Hooking up...stock 10 cd changer to aftermarket Radio
im wondering if you can Hook up...a stock 10 diskcd changer to aftermarket Radio (sony explod) cause i wanna use it
Old Jan 8, 2007 | 07:39 PM
2001gt3.0's Avatar
Default RE: Hooking up...stock 10 cd changer to aftermarket Radio
**What is the model of your Sony Explode? You mayneed to look at doing something else.
I believe that your going to run into a few problems:
No CD RCA inputjacks on your head unit, no output RCA jacks from your CD changer, no CD controls on your headunit, you would also need a D/A converter for yourCD signal that comes out of the CD changer.
I have seen some Sony after market CD changers that will work with the Sony inilink receivers, however, I am not sure if your Sony Explode's head unitwould havea matching Sony CD changer.
Old Jan 9, 2007 | 05:18 PM
it has cd rca jacks on the back of my stereo.....is there any way to put rca cables on the stock cd changer
Old Jan 10, 2007 | 09:37 PM
2001gt3.0's Avatar
You would have to find a wiring diagram for the CD changer, but even if you did, there would still be no way to control the changer from the Sony head unit.
import1978
Aug 21, 2009 08:13 AM
tarmacES
Sep 29, 2008 11:35 AM
Simss
Jan 28, 2007 12:13 AM
50ul }{4ck3r
Jan 7, 2007 06:02 PM
EclipseBabe29
May 10, 2006 02:08 AM
