Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
installing indiglo gauges
Old May 1, 2005 | 11:12 AM
XskiesoffireX's Avatar
Default installing indiglo gauges
I have a 95 Eclipse that I bought gauges for. I installed the actual gauges themselves, but I don't know how to wire them. I know you have to connect each wire of each gauge together then the last one gets plugged into the switch unit thing (forget the name) and then off of that the two red and black wires have to be connected to the headlight power switch I think it said.. I know the black one is my ground and what not just have no freakin' clue how to get to the headlight power switch... please help, it sucks driving at night with no gauges lol
Old May 10, 2005 | 10:15 PM
m3kgt_99's Avatar
Default RE: installing indiglo gauges
Hey, sorry it took me so long to reply, This is ONLY 1 positive and 1 negative wire coming out of your gauge control box; What I did is spliced the positive wire into the positive wire going to the cigarett lighter (I would suggest using the clips that clips onto the wire and you crimp the other wire into a little plug and plug it into the clip) you can get them from O'reileys, or autozone or somewhere like that. then you ground the black wire somewhere and it should work.
Old Nov 15, 2005 | 10:18 PM
anko_kun's Avatar
i instaled teh same type of gages in my 97 and i was told that if you put the power in after the dimmer hat you can possidly mess up your gages so i wired up to the main head light switch in the column and i have had no problems
the thing about after the dimmer is gust somthing i heard is it true ???? but just thought id let you know
I Drive Naked
Sep 26, 2011 12:21 AM
thehintons06
Aug 13, 2006 05:29 PM
XskiesoffireX
May 2, 2005 01:45 AM
Eclipse4ever01
Jan 20, 2005 03:26 PM
heypeck1
Feb 20, 2004 02:33 PM
