Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
2001 Mit eclipse sub..
Old 10-28-2017, 11:34 AM
Widgmaster's Avatar
Default 2001 Mit eclipse sub..
I have an after market JVC stereo if my Spyder and it has a sub outlet.so installing a subwoofer was easy. One thing I did I`d like to share is running the remote wire to the amp on a toggle switch.. Some people don't like all the thumping so I can turn it off or on depending who I`m with. Also the sub box I installed was a MTX Sub with a Pioner Amp. AS you can see in the picture I cut the box down , reported it and let the speaker drop into the center of the spare tire. I covered the bottom of the speaker box with new trunk liner material and then used fiberglass resin ..
Attached Thumbnails 2001 Mit eclipse sub..-20170612_083723.jpg   2001 Mit eclipse sub..-20170612_083735.jpg
hawky
04-13-2022 01:49 AM
Dale Sommers
04-01-2017 01:49 PM
fsccribeiro
02-12-2008 08:54 PM
jwngr
1st Generation
11-18-2007 10:44 AM
sportbackdad
06-04-2004 08:21 AM
Quick Reply: 2001 Mit eclipse sub..
