Original Radio Hidden menu
1 Attachment(s)
Hello fellows. I have an original Mitsubishi navigation on my car and want to install a reverse camera. All connectors are there but nothing happens, as the device cannot see the camera. I guess i need to enable it but I cannot find where. How do I get into the service / settings menu?
Thanks |
Originally Posted by Panos Holst Mitkas
(Post 319529)
Thanks But a friend working for Mitsubishi told me the solution. From settings->SW info > touch the screen in each corner in this pattern : Top left , top right, bottom left, bottom right Engineering menu should show up and allow you to enable reverse cam |
(Post 319529)
Thanks I just posted the video showing the process here: |
There is another hidden menu on the same page. Click 5x bottom left and 1x bottom right. Some menu items are Chinese, maybe someone can translate them. The camera menu is there too.
Hi
Originally Posted by gor3
(Post 323260)
Hey, same problem here.
But a friend working for Mitsubishi told me the solution. From settings->SW info > touch the screen in each corner in this pattern : Top left , top right, bottom left, bottom right Engineering menu should show up and allow you to enable reverse cam I have a mitsubishi space star 2021 end i can't join in this menu |
