Audio/Visual Electronics Wired up? Everyone's got some sort of electrical modification. let's hear about it here.
Radio static when revving engine
Old Jan 14, 2007 | 12:49 PM
R3D's Avatar
R3D
Default Radio static when revving engine
Doies anyone know anything about a static/buzzing noise comoing from the radio when you rev the engine in low gears? I remember having this issue with an old VW scirocco and one fix was wiring a capacitor across the alternator (or something like that, I forget). Any input towards a solid solution would be greatlyappreciated.
Thank! [8D]
Old Jan 15, 2007 | 12:44 PM
Karter17's Avatar
Default RE: Radio static when revving engine
Check your plug wires or theres a condenser on the distributer for static electricity that might need replaced. I had static on the radio and replaced both and the radios great now has no static at all. This was on my 92 mirage so I don't know about your VW but try the same things.
Old Feb 22, 2007 | 07:51 AM
WPSpyderGT01's Avatar
make sure all connections are taped or covered.. also.. keep RCA's away from the Wires *red* *yellow* etc.
Old Feb 22, 2007 | 11:50 AM
RCJr9186's Avatar
sounds like a ground problem to me. check all of your grounds! amp(s) and head unit.
Old Feb 22, 2007 | 02:37 PM
come to think about it... it does sound like a ground problem.. one of them might be loose.. or just not connected properly
Old Apr 10, 2007 | 11:22 PM
antlip's Avatar
Do you have after market amps if so it couldbe alternator whine. Try ground loop isolators on the RCA jacks.
Old Apr 10, 2007 | 11:28 PM
Grounds
Old Apr 11, 2007 | 03:22 AM
50ul }{4ck3r's Avatar
thsts what i was going to say...X2
Old Apr 11, 2007 | 10:31 AM
Dusty Eclipse's Avatar
Yup
Old Apr 11, 2007 | 02:10 PM
ORIGINAL: Sebba
Grounds
ORIGINAL: 50ul }{4ck3r
ORIGINAL: Dusty Eclipse
Yup
lol...But Ya It Sounds Like A Ground Wire....My Buddie just told me he had that same problem
