Will this 18" sub work with my amp?
I have a 1000watt sony amp. What I want to know is if the sub I want will work fine with no troubles. Just want to run the 1 sub.
SAYS SONY XM1652Z 1,000 WATT 2 CHANNEL BRIDGEABLE CAR AMPLIFIER Description THE SONY XM-1652Z 1,000 WATT 2 CHANNEL MAX CAR AMPLIFIER COMBINES POWER, EFFICIENCY, AND THE GREATEST FEATURES INTO A BEAUTIFUL DESIGN. THIS AMP IS PERFECT TO POWER YOUR SUBS OR INTERIOR SPEAKERS. IT CAN BE BRIDGED TO 1 CHANNEL MONO MODE AND RUN ONE SUB WITH 1,000 WATTS POWER, OR RUN IN 2 CHANNEL STEREO MODE AND RUN 500 x 2. YOU CAN EVEN SPLIT IT INTO 4 CHANNELS IF YOU WANT TO POWER 4 SPEAKERS. Features: 500 watts x 2 channels 1,000 Watts Total Output low-pass crossover (50-300 Hz, 12 dB/octave) variable bass boost (0-10 dB at 40 Hz) Tri-way capable 15-3/4"W x 2-3/16"H x 10-7/8"D stereo 2 channel or bridged mono output 4-ohm stable when bridged Tri-way capable MOSfET power supply preamp and speaker level inputs preamp outputs gold-plated connectors WILL IT WORK WITH THIS SUB? SAYS This is a brand new single, factory sealed, never been opened Acoustic high performance subwoofer. When you need a high power 18” sub for the competition rounds, this is the one! It’ll handle up to 1000 watts of rock solid pounding bass all day long! This is from Acoustic’s new B.A.S.S. (Bad *** Serious Sub) line of subwoofers. This sub is designed to play loud and win competitions. It features a 4 ohm 2” Parabolic RFL voice coil for 40% more power handling capabilities, a 60 oz. magnet, an oversized rubber surround, and a Poly Zirconium cone for 25% tighter and punchier bass. Because of the “Mid Q” design, you can use a ported or sealed box. It also has CEA Cooling Technology with a vented and extended pole piece to disburse voice coil heat and increase reliability. Designed and engineered in the USA. We are an authorized Acoustic B.A.S.S. Internet dealer. This comes with a full 3 year warranty. WARNING: This sub is capable of producing dangerously loud SPL levels. Acoustic 18” High Performance Subwoofer Designed and Engineered in USA Power Handling Capabilities: 500 Watts RMS to 1000 Watts Maximum Recommended Power: 60 Watts to 1000 Watts 2” Parabolic RFL Voice Coil 60 oz. Magnet Oversized Rubber Surround 4 Ohm Impedance Poly Zirconium Cone Efficiency / Sensitivity 94dB @ 1 Watt / 1 Meter Polyimide Voice Coil Former Mid Q Design for Versatility in Enclosure Compatibility Flat Progressive Roll Spider CEA Cooling Technology Vented and Extended Pole Piece Low Carbon Top and Bottom Plate Weather Resistant Design Approved for Car Audio and Marine Use 3 Year Warranty |
RE: Will this 18" sub work with my amp?
Yea it will work, i wouldnt bridge it though. If you do, dont run it full blast. You would be pushing 1000 watts to it. Recommended is 500 on the sub hince 500 Rmsgb
Who in the sweaty hell would make a 18" subwoofer that is only rated at 1kW? What brand is that?
ORIGINAL: Dusty Eclipse Who in the sweaty hell would make a 18" subwoofer that is only rated at 1kW? What brand is that? http://cgi.ebay.com/ebaymotors/18-In...em130194337337 |
I wouldnt waste my money on that if I were you.
buy a 13.5 inch w7. their only around $600 a sub lol.
Also, what are you powering the system with?? You would probably need to beef up your power source too..I would think you should get a Stinger dry cell battery, capacitors, beefier alternator, alternator relay, a line driver wouldn't be a bad idea either....DON'T GO WITH E-BAY JUNK!! SAVE YOUR MONEY AND DO IT RIGHT! Here's what my system is and I'm hittin' well into the 152 DB's with the gains on my "sub amp" turned only a quarter of the way up;
Shreffy's Stereo System: 2 Earthquake Magma 12 inch subs, 6 1/2 inch Earthquake mids in the doors, 3 1/2 inch Earthquake tweeters w/crossovers in the dash, Earthquake 6x9's in rear, Pioneer 6600 head unit with screen savers, Earthquake DHC 200 digital amp for subs, Earthquake 4 channel amp for highs, Audio Control line driver in console, American Eagle capacitor, Stinger dry cell battery in trunk, Stinger fans to cool amps, Pro Power 210 amp alternator, Stinger alternator relay under the hood, all Stinger wiring and RCA's, custom vented and ported enclosure made from 3/4 inch MDFcustom made in the trunk to fit it perfectly. |
Not a bad setup... though whats with the walmart head unit? lol
Hahaha..You know, I wonder that myself a lot when I look down at it while I'm in the car...Well I kinda scored that one cheap from a buddy of mine...he only had it for 3 weeks and wanted to sell it and sold it to me for like $80...my last one was pretty old so I bought this one cuz it was still about brand new then...I am going to upgrade probably this summer and the 6600 is gonna go in the Jeep.
Just checking :D
| All times are GMT -5. The time now is 06:18 AM. |
