idle air conttroller
hello everybody........
i have the idle failure in my eclipse 97 gst turbo..... what another car idle and water pump can fit it ?? i heard that the galant can fit somehow?? please answer me guys i need ur help cause im in dubai and no parts available in the agency in here :mad::mad::mad::mad::mad::(:(:(:(:(:(:( |
Take the IAC out and clean it. What's the watr pump got to do with it?
yes bro...... the water pump is damage too....i found out tha galant 94 to 98 is fit well..... is that right ??
and also hyundai sonata ISC can fit in my eclipse too ?? is that correct ?? |
bodies,,,,,,,,,, well ill check if its gonna work if i clean the idle.....
you guys what do you think cause i got advices from friends that i have to use the brake protect cleaner not the engine cleaner ((WD40)) for the idle ? advise me please |
Guys I kwait remove the throttle and cleane the idle and still I have the same problem the car keep switching off when on P and the AC is working
Rather than that the RPM on 3000 omfg What the **** I can do pleaaaae help |
Sell the car, clearly you have no clue.
