2.0lancer02 |
01-11-2011 09:41 PM |
02 lancer weird rough idle
its an 2002 lancer with a 2.0 automatic with just under 300,000 miles. the problem just started a couple days ago. i live in a cold area like when i start it in the morning its 15 degrees outside. ok so when i start it it starts and revs down to 800rpms for ten to twenty seconds then it spikes to 2000rpms and the fast idle works fine after that. once it warms up and revs down back to 800 it random misses. no engine light havent hooked a scanner to see if there is pending codes. if its in gear it quits missing if its in park or neutral it starts missing. if its in gear it doesnt miss at all. The weird fast idle and the idle miss happend around the same time so thinking both are linked to the same problem. i put new wires on about two years ago and plugs but i just changed plugs 4 months ago. put in ngk plugs not the cheap ones. could it be bad gas but i wouldnt think it would mess up the fast idle. any advice would be greatly appreciated thank you. any questions just ask.
