1988 Mighty Max
I just acquired a very nice 88 Mighty Max Pick-Up that has a few problems. It has an automatic transmission, and factory A.C. It runs great, but has a water leak on the drivers side of the engine that pours out faster than I can put it in with a container. I have to just leave the water hose in the radiator to fill it up. Without unbolting a lot of stuff, I find it impossible to see where the water is pouring from. Does this engine have a freeze plug there? Could it be a busted block? There is no water in the oil at all, and no oil in the radiator. Any ideas on what other automobiles has an engine that would just swap with this one without a lot of modifications? The only information I have on it is as follows:
1988 Truck MB 550670 Mighty Max Vin # JA7FL24D4JPO72822 Cyclone Engine -- G63B Thanks |
RE: 1988 Mighty Max
All i have to say is take that motor out and drop a 4g63 eclipse or talon turbo motor in it
RE: 1988 Mighty Max
i have no clue man but i ran a search and this is what i found
http://www.automotiveforums.com/vbulletin/f1119/ (hit the search key to get the links) that is the forum that 88 mighty max is mentioned alot. http://www.wiegand-liners.com/contac...nes=mitsubishi another one and for the manuels http://www.repairmanual.com/automobiles/1988/28 and one more http://search.yahoo.com/search?p=hay...tab-web-t&b=11 i have no idea about the mighty max but i am sure you know what your looking for i hope you caN find it in there gl |
will 4g63 mate with the 2.6 transmission?
Originally Posted by 88mightymax4g63
(Post 18615)
