-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   1992 eagle talon (https://mitsubishiforum.com/forum/everything-else-37/1992-eagle-talon-3497/)
phil me in Feb 27, 2005 07:01 PM
1992 eagle talon
what do u think thin car is worth 92 AWD 6 bolt/4 bolt 22K on Engine, 12K on transmission and turbo, 102K on body Motor Built by Thomas Automotive Developement 1991 Block bored, (.20 over), honed, and balanced ported and polished head with 3 angle valve job New crankshaft JE 9:1 pistons with Total Seal Rings and stock reconditioned rods ARP studs Clevite Bearings 4 layer mitsu Metal Headgasket Balanced Shafts, A/C, Cruise Removed Prothane Motor Mounts all gaskets,waterpump, and complete timing assembly changed about 500 miles ago. $1600 dollars spent on parts and labor. *have receipts 16g - Ported w/34mm flapper ported 2g manifold, ported O2 housing stainless steel manifold to head bolts (wont break) Fluidyne Aluminum Radiator Turbo XS boost controller Autometer Boost, Water Temp, and EGT gauges BM Tranny built to 1994 spec. 4 spider differential ACT 2100 pressure plate with puck disc Symborski shift kit KYB GR2 shocks, Eibach Pro Kit Springs Front strut tower bar, Front cross drilled rotors 1G Mass Air Flow Translator GM 3 MAF Sensor 3inch intake pipe Walboro 255LPH fuel pump 550cc RC Engineering injectors Bolt on adjustable fuel pressure regulator w/ gauge Dsm chip eprom modification with injector compensation, launch feature, no lift to shift, etc. (keydiver) brand new plug wires NGK 7es plugs sony 6X9s Alternator, Headliner,, Pass. Side Axle, Rear CV Boot, Hood, Wheel Bearing, Valve Cover and had it powdercoated, Oil Cap, etc. The bad: drivers side key hole doesnt work, must be unlocked from passenger side (never got it fixed, im sure its very basic b\c power locks work) Missing stock ground effects panel near tire on passenger side ( have replacement, just needs to be painted) some small dents,scratches,and minor paint chipping where panels meet, one dent on roof, Thats about it. Lots of receipts from me and previous owners, includes all major ones of course for proof of work done. Mechanically solid. the guy is asking $4,800, what do u think i should offer him?
1398spdr Mar 1, 2005 05:10 PM
RE: 1992 eagle talon
sounds like a pretty good deal, u said the engine has 102k on it is that before or after the rebuild......... hows it drive, otherwise id say go for it, do you know the mechanic personally, if so do you trust him...................
