1998 Eclipse Spyder gst- no start
I was changing the fuel pump.I did try one time to check if the fuel line was leaking. Then i did try to start it. That did not work.
I was running good before fuel pump change. The car is cracking, batteri is good. Now the fuel pump is not running while i am cracking. No tachometer CAS or CPS ? :confused: |
