-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   2000 Eclipse GT 6cyl (https://mitsubishiforum.com/forum/everything-else-37/2000-eclipse-gt-6cyl-36146/)
nostrashawnus Jun 12, 2010 02:55 PM
I have a question. After running fine for years, last night my eclipse decided to not start.
Here are the symptoms:
1. Cranks just fine
2. The windows will not roll down
3. the radio works fine
4. The sunroof will not open
5. The fan will not turn on
As I am a Chevy guy, and this is my daughters car I need some assistance! I checked continuity on the relays in the under-hood fusebox. I looked at all the fuses and they seem fine. I do not hear the fuel pump prime when I turn the key to start, but I have read conflicting info on whether or not it should make noise. I have seen many posts about the Fuel Pump Relay, but I have not even found where it is to check it. (once again several posts with conflicting information) So if someone will send a pic that would help me greatly! Any other information or things I can check? I really do not want to take this to the dealer as I am sure it is a ECM or relay that is causing this issue.
Thank you all for your help!!
MitsMaster Jun 16, 2010 10:06 PM
Im thinking Ign switch. mounted on the end of the ign lock cylinder. 6 wire connector.
