91' eclipse gas pedal
my gas pedal in my 91' eclipse is extremely stiff, and when i let off its delayed and sticks a little bit, some of my friends told me to use WD-40 or something like that, but i'm not sure where to put it.
RE: 91' eclipse gas pedal
First go get some carb cleaner NOTHING BUT CARB/THROTTLE CLEANER!!and clean your throttle body......if it still persists then check you gas peddle cable, but most likely its just a dirty throttle body.
thanks, i'll try that
i checked my throttle, and its loose, so is the cable going to the throttle, any other ideas on why my pedal is so stiff?
maybe check the coil on the back of the trottle body, i know i had that problem. Just spray some WD-40 on the small coil and it should fix it.
yeah, i looked at that, and i think thats what i need to do, thanks
