96 eclips
need some info I have a 96 eclipes , after driving about 30 min the engine light flashes and the car starts to stall and buck it has all new wires plugs coil and the code is for a miss fire any help would be appreciated thanks
RE: 96 eclips
The engine light never stay's on? Is it predictable, so you know when to expect it?
RE: 96 eclips
A check engine light means there's a problem BUT If the light flashes- it means that the problem detected is severe enough to cause catalytic converter damage if you continue driving under these conditions. This usually warrants a bigtime and very noticable misfire. Have it inspected asap or you may have more issues to deal with ontop of your misfire. Does your misfire code specify a specific cylinder?
Joel, CA |
RE: 96 eclips
Damit I'm a moron, joel is right....I didn't read your post right. Same thing happens on Toyota's. On very rare occasions this problem can go away depending on how serious it is. The misfire may only have happened once and now that cat can be plugged up and tad and the computer is seeing this through your bank two O2. Its tough to say....How many miles are on your car? or cat for that matter?
