-   Everything else (https://mitsubishiforum.com/forum/everything-else-37/)
-   -   99 eclipse motor mounts (https://mitsubishiforum.com/forum/everything-else-37/99-eclipse-motor-mounts-33733/)
eclipselaxr18 Sep 11, 2009 03:11 AM
what would be the easiest way for me to change the motor mounts on my 99 eclipse they need to be replaced asap so any advice would help greatly and should i replace the entire motor mount or just the inserts thanx much
TheEngineer Sep 11, 2009 06:50 AM
well i cant tell you unless i know what problem your having. Im assuming your saying its just the inserts that are worn in that case id say just replace them. And the easiest way is to just do them one at a time and use a jack under the motor if it needs it
eclipselaxr18 Sep 12, 2009 02:17 AM
yea its just the inserts but i didnt kno if it was one of those if one parts bad replace it all kinda thing and what type of inserts should i get i was thinkin just getting some oem replacements autozone or some place like that
