99 montero noise
Hello- 99 montero xls....over the past 12 months, when on the highway accelerating to 65 to 70 and above a noise almost a rubbing sound emenating from the left front wheel?, a slight tug is felt in the steering wheel, decelerating stops the noice...does not always happen, sometimes it seems to happen on windy days only...any thoughts?
Browndog |
RE: 99 montero noise
check the barometer before you head out.[sm=smiley8.gif] no really does the pull correct itself when you decel? when was the last wheel balance/alignment/toe in? have you checked the inside of the tire for broken belts?
