ABS Traction warning lights
Hi. I have multiple lights on the dash which are the ABS, Traction control etc along with the red warning lamp to stop. You can here the ABS pump surging when the ignition is turned on as normal but it doesn't seem to stop surging? I'll attach the diagnostic codes below. Thinking it may be a bad earth to cause so many fault codes but I'm not sure?
Give us another clue... Maybe what car are you on about?
Mitsubishi Shogun/Pajero 2003, LWB, 3.2 DI-D, Diesel, Automatic
| All times are GMT -5. The time now is 09:49 AM. |
