Adjust The Idle
Hey Guys,
You guys are great. I am having a problem with starting my car (92 Talon). And when it does start it idles really low...Like 700-800 rpm....I also have trouble with jerking and gurgling like there is too much air or not enough gas. #1 how do you raise the idle #2 what is your best guess on the prblem?? Thanks a ton.. John |
RE: Adjust The Idle
the idle adjustment screw is right on your throttlebody sticking strait up. it may have a black rubber plug over it. you can try that but it sounds like you have more of a problem, and you need to give us a lot more info..
