air/fuel ratio
I have a 3000gt and i just bought an air/fuel ratio gauge but it says that i need to connect the signal wire to the 02 sensor, anybody knows where that is??
RE: air/fuel ratio
they are in the exhaust. one is pre cat and one is after the cat.... I added a pic here of my EVO under the car you can see my exhaust there is a wire hanging down and the end connector is plugged into the exhaust that is an o2 sensor
[IMG]local://upfiles/3652/317FA7CE79EE4D138EFE80BD113BAE08.jpg[/IMG] |
RE: air/fuel ratio
oh and the wire wont be hanging of course but youll see the o2 sensor sticking into the exhaust
RE: air/fuel ratio
Go here http://www.3si.org and seach for a ECU diagram. Then tap the O2 signal wire that leads to the ecu plug its self, its much easier that way.
RE: air/fuel ratio
Do you need to buy and A/F sensor made for your car or are they all the same?
RE: air/fuel ratio
no they are all the same
RE: air/fuel ratio
A\F gauge is kinda worthless in tuneing it realy doesnt help unless its a wideband with o2. they are all universal wide or narrowband just need to splice it all in;)
RE: air/fuel ratio
ORIGINAL: EMonz57 A\F gauge is kinda worthless in tuneing it realy doesnt help unless its a wideband with o2. they are all universal wide or narrowband just need to splice it all in;) |
