| Chiffy |
Jan 11, 2025 11:59 AM |
Battery draining. ASX 2015
mitsubishi ASX 2015. Battery draining. Have disconnected negative terminal and connected meter, reading .35 amps constantly. Removed all fuses and relays in main fuse board, still getting a reading of .35 amps, removed fuses individually in fuse board in cabin passenger side, still reading .35 amps. Anyone got any ideas on what could be causing this, or is this reading normal and battery is faulty? Are there any other fuses or relays which could be at fault? Any help or advice will be gratefully received.
