battery light and brake light stying on on dash
I have a 2005 lancer es. I just changed the radio. I blew the fuse when changing the radio. After pulling out some of the fuses I finally found the right one and changed it. Everything seems to work ok but... the battery light and brake light will not go out. Could I have done something to the fuses to cause this to happen. Any help would be very appreciated.
Try checking all the fuses.
I will go through them today and then report if it works.
Switched some fuses around and now everything is working as it should
