Blinker won't stop flashing
Hello Can anyone help me out? I am having trouble with my left turn signal. It was working fine I went to make a left turn and the handle click back to its original positon but the light continues to flash. When I click it to the right signal it doesn't do anything no light at all but the handle clicks. I tried changing the fuse but no luck. It still is flashing only goes off when I turn off the car. The headlight work fine and the hazards are okay as well. DO you know what may be causing this? What would it cost to repair?
RE: Blinker won't stop flashing
check the mulitfuncation switch.
no. change out the turn signal switch, its broke
ORIGINAL: tjbiker031 no. change out the turn signal switch, its broke The turn signal switch is the multifunction switch. |
my bad
