car mortor bogs help
got a 99 spyder eclipse and when i press on the gas the motor bogs and feels like it doesnt want to pull but after 3500 rpm its fine again any ideas what that could be help
thanks |
RE: car mortor bogs help
Is this a turbo? If it is, it sounds like you have something disconnected in the supply air. Check to make sure everything is connected between the air filter and the throttle body. If everything is okay, it may be dirty injectors.
its a NON turbo but that is what i was thinking off dirty injectors but sometimes if you have a Bad distrabutor it would do the same thing i would think but may be the gear box also i dont know but well double check again =0 thanks for the reply bro
might even be a dirty air filter
