cold idle
Old Mar 28, 2006 | 09:53 PM
chiefshoe's Avatar
Default cold idle
[size=3]91 sohc during cold idel my car idles rough and back fires but as soon as normal operating temp is reached no problems any ideas on how to solve this
Old Mar 28, 2006 | 11:29 PM
slow420a's Avatar
Default RE: cold idle
I think your caps button is stuck down, here is a little pic that may help you with that problem
Now for the back fiing and what know try changing the plugs and wires.
Old Mar 29, 2006 | 12:03 AM
stpracer's Avatar
Backfire out the exhaust or out of the intake? Could be a sticking choke, a vacumn leak, or an idle control value.
Old Mar 29, 2006 | 12:56 AM
slow420a's Avatar
Its most likley going to be out the exaust, its an efi motor, the only efi motor that I have seen back fire out the intake was a ls1(really short intake runners) and it was spraying a huge dry shot. The back firing is caused by excess fuel exploding out side of the exaust valves. That can be atributed to bad spark or bad o2 sensors. O2 sensors need to be heated before they work right, but plugs and wires are cheaper thats why I recomened replacing them first. Insuficent spark is the cause of many problems.
Old Mar 29, 2006 | 08:29 AM
chiefshoe's Avatar
Thanks for the help, I replaced the plugs and wires in Jan however I will get and intermittent CEL 11 which is the oxygen sensor but currently the CEL is not on. So it looks like its time to spend the 90.00 for a new one.
Thanks again
PS I dont see and CAPS in the first post?????
Old Mar 29, 2006 | 09:57 AM
thats wierd cuz i see the CAPS too....
$90 for an 02 sensor?! thats overpriced. You should be able to get one for maybe $50.
Old Mar 29, 2006 | 10:24 AM
slow420a's Avatar
ORIGINAL: TheEngineer
I dont know about that one, I dont think i have enen seen one that low even on the net. For a gst oem one its 120 at the dealer, but on car-parts.com its 90 and change.
Old Mar 29, 2006 | 10:49 AM
i got a cheap one from autozone.
Old Mar 29, 2006 | 01:37 PM
dirtwagon's Avatar
ORIGINAL: slow420a
No expert here, but I thought that CAPS meant the words were all capitalized. It looks like he increased his font size
Old Mar 29, 2006 | 01:51 PM
slow420a's Avatar
ya I got excited and nervous.
